37-620 RF Transformer
I have a 37-620 that was working after restoration but now the broadcast band is down. I isolated it to the RF transformer part number 32-2108. The primary appears to be open. I have no experience with winding transformers with mag. wire.
Is there a place to buy the part? If not are there step by step instructions for winding your own? Also would a different RF transformer part number work as well?
Thanks for any help
Check here: http://www.philcoradio.com/resourceb.htm#v
and you can put a Wanted Post up in case someone on the Phorum has one.
Philco 91 Restore Code ??
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 6037 online users. [Complete List]
» 1 Member(s) | 6036 Guest(s)
