  • 1 Vote(s) - 5 Average
Starting work on my 19B
#61
The 75 for sure, you can experiment with the others, but mine plays fine without the 36 shield.
#62
Steve, Skyscraper,
I put the two shields on the 44 IF and the 75, then played the radio for about 20 minutes. I couldn't get it to go into oscillation though I was playing w/ the volume control a lot. Hopefully, that issue is resolved.
Thank you both!
Jon
