list of common antique radio tubes
does anybody know where i can get one? i'm thinking of buying tubes in bulk (there's an ad in my local paper for some) and i don't want to get stuck with old tv tubes. thanks!
The best way to collect tubes IMO is to buy tubes that are used in the equipment you own or plan to own your self. Then slowly add more numbers as you learn more. If you want a complete collection of old radio tubes I hope you have a lot of room, time and money. Also expect some people to think your nuts.Icon_eek
Some info links
http://www.vacuumtube.com/FAQ.htm
http://www.vacuumtube.com/tuner%20tubes.htm
http://www.oldradioparts.com/pg1.htm
Good luck!
Bill
It's not what you don't know that hurts you it's what you know that's not so.
Paul has put together a list of many common radio tubes:
http://personalpages.tds.net/~pdieten/tubes.pdf
Carl
Northern Panhandle, WV
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 5731 online users. [Complete List]
» 1 Member(s) | 5730 Guest(s)
