Station Call Tabs for 39-116
Hi-
I'm looking for some original call tabs for the 39-116: they seem to be a bit larger than the "standard" size.
Any assistance you can offer will be appreciated.
Regards,
Lew
Not commonly available, and not being reproduced. You can make your own on your computer if you are so inclined. Icon_smile
Eico 232 VTVM Schematic
There are currently 6417 online users. [Complete List]
» 1 Member(s) | 6416 Guest(s)
