39-25 Project
#31
Hi Bob,
Nice job !
Was wondering how well did the paint stick to the hosing?? I find that most of the time it ends up beading up on it and won't stick.
The paint stuck pretty well. I did rough up the tubing with some 220 grit sand paper and I think that helped. It took a couple coats for the base coat; I'd put some on, hit with the heat gun for a few seconds to dry and put another coat on and sometimes a third coat just to make the color even. I used Americana Acrylic paint. Easy to use and easy to mix for custom colors.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
There are currently 3655 online users. [Complete List]
» 1 Member(s) | 3654 Guest(s)
