Philco D-10A Cartridge
The Philco 46-1209 that I am working on for a friend has the D-10A magnetic cartridge. The cartridge works and has an original style needke in it so it is OK. has anyone found a source for these needles or are they still unobtainium? I need to re-flock the turntable and get a new idler but I don't want to spend that money if I can't provide my friend with a player that he can't get spare needles for.
What about the possiblity of converting it to the D-10 crystal cartridge which I understand is still available? I know the output will be higner but that can probably handled with some mods. I was thinking more of mounting the carttridge.
Any other suggestions?
Wayne
You have to get real lucky to find a needle for the D10A, I found one on ebay once, only once. it is virtually uno btainable, there are others still trying to find one. I hear you can switch to the D10 tone arm with the crystal cartridge instead.
Keep checking ebay it's your best bet I was luck enough to get one.
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 2232 online users. [Complete List]
» 2 Member(s) | 2230 Guest(s)
