The radio cloth
Hi,
It may be a long shot, but still worth asking.Original cloth is in the very good condition, just weathered. Glued to the plywood removable frame. looks new from the back side. Is there any way to have it removed and flip over? I was thinking to use some steam, perhaps.Have nothing to loose, as I restore the cabinet and will need new look anyway, so if it is damaged- be it, will get the new one, but it is not the same. Any ideas? Thanks.
You can try heating the glued edges with a blow dryer. It may loosen the glue.
If you can get the glue off , that is great but I have not been able to get it all off , ,but as you say ,if it does not work put a new cloth on.
It might be worth a try, depending on how close a pattern you can find if it does not work.
Since then I was able to remove the old fabric twice (table top sets) by gently blotting the edges with a lacquer thinner and pulling them away. The speaker side is usually not weathered and very close in pattern to the face side. I believe it could be reused.
Yes, and if there is enough length and width, the cloth may be moved a bit to displace faded areas. Some cloths were affixed with "water glass" which is soluble in, guess what? A cardboard equivalent replacement substrate can be made with patience. Even a tear or two can be fixed by a sharp eye (certainly no longer mine,) and some thread.
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
There are currently 1906 online users. [Complete List]
» 3 Member(s) | 1903 Guest(s)
