Can anyone identify this little Jewel radio?
The closest I could come is a Jewel 300 that uses the same nameplate:
http://www.radiomuseum.org/r/jewel_ele_300.html
Made by Jewel Radio Corp., NY
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
