Philco Flexible Resistor wattage rating
What is the wattage rating on the Philco flexible resistors?
http://www.philcorepairbench.com/flexrest.htm
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Eico 232 VTVM Schematic
There are currently 9214 online users. [Complete List]
» 1 Member(s) | 9213 Guest(s)
