Philco model 20 power transformer taps
I'm not sure what terminal is what on this,and is the pigtail wire coming out of it the center tap?And what is the wire coming out of the connector board hooked to??
[Image: http://i1217.photobucket.com/albums/dd38...000700.jpg]
I don't have a model 20 to compare to.
Thanks!
Phil
Never mind,I figured it out-the wire is the CT for the 27's and the 24a's,it goes to the HVCT.
Phil
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 1902 online users. [Complete List]
» 2 Member(s) | 1900 Guest(s)
