Philco 42-390
I need help restoring my Philco to working condition. I am looking for a recommendation for radio repair in South Jersey. I have no idea where to start, but looking forward to learning.
Brett
Welcome.
Well, this site has tons of information, so find the recomendation on starting or simply look up any thread on restoring a radio - they often start alike.
there are common sense things, like
Do not plug it in.
Take teh chassis out.
Clean it,
check tubes
recap it
change out of tolerance resistors,
inspect wiring, panels, connection etc.
You will need to find the schematic - there is Rider manual on Nostalgiaair.org or you could order a high quality stuff from Chuck Schwark at Philco repair bench site.
There are also cabinet repair experts here who will help you.
Philco 91 Restore Code ??
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 5923 online users. [Complete List]
» 2 Member(s) | 5921 Guest(s)
