620b - worth it? (Bought it)
It's not bad, but I think you should save your room for an even better console. Icon_smile
Thanks Mr. Philco, I'll stay with the 620.
Now, just to wait for that beautiful $20 16B with working shadow meter to pop up. Any day now Icon_biggrin
Felix, yep. Sounds good. I already have two. While we're shooting for the sky, I guess I'll wait for that mystery control set or maybe early 30's phonograph.
Success! Picked it up this afternoon. Looks good, but poorly refinished. Pictures to follow when I get home.
Thanks for the suggestion everyone!
There are currently 8560 online users. [Complete List]
» 1 Member(s) | 8559 Guest(s)
