Magnavox CR-192 FM Tuner Dial Scale
I recently picked up a Magnavox CR-192 FM tuner. Unfortunately the dial scale is broken. I have not been able to come up with a reproduction or a replacement. Has anyone had success creating their own dial scales using a clear transparency sheet?
I've done that several times, but I need a significant (most) part of the original dial to make it happen, or a good quality scan of one.
Thank you for the feedback. I will keep that in mind.
It looks like I have found a replacement dial scale.
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
There are currently 1899 online users. [Complete List]
» 3 Member(s) | 1896 Guest(s)
