philco 41-245 escutcheon
Anyone know if a reproduction escutcheon is available for the philco 41-245.heated mine and helped it some but shrunk so much it still wont line up with the screws--thanks
No repros that I know of
Kirk
Here is a link to a page with a photo of a Philco 41-245 where the owner made a new one out of wood. It looks pretty good.
http://www.angelfire.com/planet/shelbydo...1940s.html
thanks for the replies.have to see what I can come up with.great working radio
There are currently 4059 online users. [Complete List]
» 4 Member(s) | 4055 Guest(s)
AvatarAvatarAvatarAvatar
