  • 1 Vote(s) - 1 Average
Philco 38-7 Radiobar Restoration
Take a look here http://www.antiqueradios.com/forums/view...5&t=252473
M R Radios   C M Tubes
You know, excellent quality Bojemian or Russian crystal does not sell even close. This is plain nuts.
I know, it's stupid, if I had one without the glassware I would probably just find similar looking gold leaf glasses to fit in the bar just so I could use it. His prices are completely out of line even by Fleabay standards, $40 each for highball glasses? The seltzer bottle not only did not come with the bar it isn't even in very good shape, I see rust (or some other) pits in the plating .
Well if someone wants those that bad, as we say in Russian, here, have the flag and face the armoured locomotive head on.
There are currently 8769 online users. [Complete List]
» 3 Member(s) | 8766 Guest(s)
