Dial Lamp Type for 42-380
Hello:
I'm looking to replace two dial scale lamps on a 42-380. The two that are dead are type 55. I'm not finding the correct dial lamp listing in the literature for the 42-380. The 55 is 7 volts.
Thanks for your help.
Dave
Use this chart from my site to correlate the Philco part number from the service parts listing you have with bulb types and specs.
http://www.philcorepairbench.com/lamps.htm
Chuck
Philco 91 Restore Code ??
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 3964 online users. [Complete List]
» 1 Member(s) | 3963 Guest(s)
