Philco database, start with 37 and 38-690
We need a Philco serial number database, as the Zenith collectors are building. I was thing my 38-690 Code 125 Run 4 may be one of the last made, then realized there is no way to know. It would also be interesting to learn how many of each Code and Run they made for each model. What do you think??
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Why not? Although it may have to be a "downloadable form" of some kind that is updated.
