PHILCO Decals
I am redoing this model 3650 and I will need a decal for it. What supplier has the correct one. I have heard that AES does not have the correct one.
Dan
Radiodaze.com
Perfect matches
kirk
Radio Daze item number DCL-PH8 http://www.radiodaze.com/product/6049.aspx
M R Radios   C M Tubes
Thanks guys,, I ordered the decals from Radio Daze..
There are currently 10304 online users. [Complete List]
» 2 Member(s) | 10302 Guest(s)
