Part Number(s) for wave band switch Model 60
I know the one part number is 42-1001....and am wondering if that is the rectangular shaped version with the corners nipped off so to speak and where the contact points and movement is visible. I believe there is also a round one that was used. Is this correct? Part Number? The one I have is a poor substitute. I put a WTB in the WTB section but no response. I am wondering if there is a better substitute and need info on part numbers....or any suggestions. Thanks.
There are currently 10538 online users. [Complete List]
» 3 Member(s) | 10535 Guest(s)
