16B cathedral
My chassis is done and working fine. However, there was a problem again with the dial gear. The high speed tuning was working fine on BC and ##4 and 5 bands, however slipping on the ##2 and 3. All tires and large rubber wheel had been replaced, of course. Drove me crazy for some time.
The problem was the tuner mounting. It appears, that, unless it it mounted exactly in center (and it is very easy to not center it during installation) the band switch push rod rivet rubs against the high speed rubber tire. Releasing and shifting the tuner 1MM away completely solved the issue.
[Image: http://i881.photobucket.com/albums/ac17/...b2cbf4.jpg]
[Image: http://i881.photobucket.com/albums/ac17/...0c22df.jpg]
Fields, how did you clean up the tube shields? They look very shiny and polished.
They are just wheel polished with a compound. So far I have not noticed any oxidation.I could have also nickel plated them, but there is a minimum charge which is steep for just one set of shields.One day I'll take them from all radios and plate them. Shields were easy thing to do. The rivet thing drove me nuts.
Philco 91 Restore Code ??
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
There are currently 3256 online users. [Complete List]
» 2 Member(s) | 3254 Guest(s)
