Philco 53-706 restoration Chronicles
I've never seen one of those. Love it. Just when we all think you couldn't get better you pull something like this off. Amazing.
They are pretty awesome i think. I want another one for the other side table but everyone wante too much for them online now. I paid $47.00 and now they are $150+
Thanks for the compliment
Kirk
Looks great!
original shade ?? 1960`s look ?
http://www.ebay.com/itm/Vintage-Philco-T...35dbf56408
If that is the original lamp shade I'm certain Kirk can do a lot better!
Jerry
You know me, It has to be original.
I cant believe someone bid up the one that had the lamp removed. that is just silly.
http://www.ebay.com/itm/121425036969?_tr...EBIDX%3AIT
Kirk
If this is original....the original sucks.
Original is beautiful!!!
So there were blond cabinets?
Morzh, don't avoid the discussion. Sorry Kirk, if that was an original lamp shade, well, I guess ugly is just fine! I know you like original.
Best, Jerry
There are currently 10122 online users. [Complete List]
» 2 Member(s) | 10120 Guest(s)
