Philco 90 Restoration Chronicles
Thanks Capt.!
Taped off the trim and toned. then I cleared the entire cabinet.
Now to wait 2 weeks to buff everything out.
Done!
OK, Kirk,
For this one you are allowed one B+ to the chassis Icon_smile
Great job, man!
There are currently 10402 online users. [Complete List]
» 2 Member(s) | 10400 Guest(s)
