Speaker replacement cones
 Needing to buy speaker cone for an H-7 speaker Can't seem to find right size on line. Its appox. 10&1/2 to 10& 3/4"Dia.
The ones I see for sale are 10" and 12" is there one of them that will work? Thanks for help.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
