41-250 No sound, glowing 41 tube, can't be a good thing
This discussion is very handy, as I just discovered that the output transformer on my 41-250 is bad - one half of the primary tests 12,110 ohms, and the other half 233 ohms. I was wondering which transformer to buy, and am happy to learn that the Hammond unit mentioned worked well.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
There are currently 9573 online users. [Complete List]
» 1 Member(s) | 9572 Guest(s)
