46-1209 Electronics
Z, you have listed the P/N of the caps. Easier to log the value of the caps required such as .003 etc. The style you show are just fine. Depending on how many radios your planning to do, it is often better to buy kits with quantities of a given value. Alternately buy just what you need. You will find people selling caps. One I like for simplicity is Sal's Capacitors but there are many others.
Jerry
http://www.tuberadios.com/capacitors/
I believe I have a parts chassis around here. Let me know if you need some parts, I'll see what I have.
Very Nice! I have a 46-1209 in the dining room waiting for me to finish the 42-3456 I promised to get done last year (!). I sneaked a peek at the cabinet and need to know if the "birds eye" band just below the top is faux or real wood.
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
There are currently 3158 online users. [Complete List]
» 1 Member(s) | 3157 Guest(s)
