Help reply basics on refinishing
You guys asked so  I am posting pictures on refinish basics on zenith 39a radio in the (other radios section), but I don't know how to add message with each picture. I hope this will help some of you guys that have been asking me to post some things on this subject, I don't have a philco to do at this time other wise I would have posted it in the cabinet section
Fred, you just type in the reply box like you normally would and the put the image below the text and then more text after the image.  For example it would look like this as you compose the post:
Hi I'm Fred...here are my pics showing process XYZ....
[img}https://dl.dropboxusercontent.com/u/54621529/Question.jpg[/img]
and that's how I did it....
(of course the } should really be a ] but if I did that it would not show up in the post so you could see it)
So the post would look like
[Image: https://dl.dropboxusercontent.com/u/5462...estion.jpg]
ooops...now that I posted that reply I see that you are "Attaching" the photos rather than using an off site server like dropbox or photobucket.
In that case you just have to put any text you want to include before the attached photos like you did when you said "a few more pics"
(if you want some help getting onto dropbox and adding photos that way, send me a PM and I'll help you.  Its free for up to a gigabyte or two of storage )
