40-165 button spacers?
It looks like I'm missing a couple of the spacers that fit behind the buttons on a 40-165.  Do I need them?  If yes, does a anyone have reproductions and just what are they called?
Keith
http://s50.photobucket.com/user/keithvj3...sort=3&o=0
I've never seen those before. Interesting.
I assume they are rubber? They kind of look like something to keep the dial light from leaking through the preset button holes.
John
Las Vegas, NV USA
(12-23-2014, 04:57 PM)LASJayhawk Wrote:  I assume they are rubber? They kind of look like something to keep the dial light from leaking through the preset button holes.
Yes, they are hard rubber.  I was wondering if they were there to keep the buttons from being pushed in too far.  If they are there to keep the light out I won't worry about replacing them.
Keith
looks like some one put them on maybe so they don`t push buttons in to far ?
There are currently 10286 online users. [Complete List]
» 1 Member(s) | 10285 Guest(s)
