Philco 70 Cathedral Speaker
#46
To add to that, the resistance, coil to coil, was very consistent, all those I had read very close to what it said on the sch, between 3.1-3.2K.
And in 70 this does affect pretty much very tube's plate DC. Will still work but may run hotter.
There are currently 9847 online users. [Complete List]
» 2 Member(s) | 9845 Guest(s)
