  • 1 Vote(s) - 5 Average
RCA 77V2
Hello Friends,
Attached (I hope) are three photos of an RCA 77V2 radio/phonograph combination. It came out of my grandmothers house. Cabinet is in really nice shape and it'll need recapping and rewiring. It'll be my fall/winter project. Cheers! Joe
Joe
Looks yummy. And the cabinet seems to be in a great shape.
Gonna make a fine piece of home decor, and if it plays - will turn some heads.
Thanks friends. The unit worked up to 10 years ago, but the aunts unplugged it and used it to put nic-nacs on. It has the dreaded 6X5 tube in it but I have several spares. Icon_smile Fan, as soon as I get the chassis pulled (probably October) I'll post photos to this thread. The 66X1 looks great. Joe
Joe
IT IS ALIVE!! After 2 years and countless reasons for not finishing it sooner, this 68 year-old unit is up and functioning again!  I replaced all the cracked insulated wire. I had never seen so many out-of tolerance resistors, but surprisingly, every paper cap but one still showed within tolerance. The one cap out of tolerance was labeled RCA! Next up is a Hallicrafters S-41G.  Joe
Joe
looks very nice Icon_clap Icon_clap
Thanks Sam.  That was FAST!!
Joe
Icon_clap Icon_clap Icon_clap
Looks good Icon_thumbup
I like your chassis holder.... I keep putting off ordering one, in part because I'm undecided on which size to get.
(02-01-2015, 09:20 PM)Eliot Ness Wrote:  Looks good Icon_thumbup
Thanks.  I have a small workspace (my home office desk) so I opted for the smaller of the two.  There is a piece of plexiglass underneath to protect the desk surface.  I can move the chassis holder to one side and still work at the desk.  You would definitely need the larger one if the radio has 8 or more tubes.  Joe
Joe
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7216 online users. [Complete List]
» 1 Member(s) | 7215 Guest(s)
