Philco transformer identification
Can anyone help me identify a Philco transformer with these numbers on it?
32-10125-4
H5157317
It looks like a smallish power transformer but the lead colors aren't standard and the DC measurements don't seem to make sense. The one I have is new and has been in my junk box for many years.
Thanks.
Charles W4KEP
Hi Charles, Welcome to the Phorum!!!
There are some folks here with old catalogs that will probably be able to answer your question but in the mean time... Icon_wave Icon_wave
