Philco bakelite block 7762 B
I am elbow deep in restoring a model 59 and can't find any info on this particular bakelite block. I know the capacitor values. I just need to know the lugs each go to. I found info on 7762 but no B. Can some one help please.
thanks
Chris
http://www.philcorepairbench.com/bblokcap.htm
Check Chuck's site(link above) and part way down the page he has:
CONDENSER TYPE 7762
Working Voltage 600
Part No. 7762-B
Lugs Used 1-3-6-8
Cond. Mfd. .001 1&8-6
Cond. Mfd. .015 3-6
and the pic, of course.
He might send a better link.
Scott
Old Cars, Old Radios, Old Pipes and Young Women... What more is there?
Nope, he won't. That's the link!
Icon_biggrin
Here's a drawing. Hope this helps.
[Image: http://img289.imageshack.us/img289/2315/...can0ca.jpg]
(edited by site admin)
Sorry. My lame attempt at posting a photo failed. Looking at the drawing on Chuck's website, Your .001 cap gets hooked to pins 1, 8, 6. Your .015 cap hooks to pins 3 & 6.
The image link should have worked, but didn't?
EDIT: When posting images, be sure the "Disable BBCode in this post" checkbox is NOT checked, else instead of your image, the code will display instead.
Icon_biggrin
Thanks everyone. I must have overlooked that. I could not find it on Chuck's site when I looked. Also the schematic says 0.0001uf. I am right in assuming I can replace that with an 0.0005 cap?
How good of a performer is the model 59?
thanks
Chris
Chris,
That's a .001 cap, NOT .0001!!!! A .0005 will be too small!
Ed Martin,
Benwood, WV
Ed,
Schematic must have a typo then. Will put in a 0.001 cap instead.
thanks
Chris
The schematic is correct (at least on mine) where it reads 1,000 uuF (pF). The parts list is incorrect in that it calls for a .0001 uF when it should be .001 uF, as Ed said. (.001 uF = 1000 pF)
