Threads: 416
City: Boston
While scrolling around the Attic Archives I came across a Philco lookalike, which came first? Anyway my question is about Rola. was Rola the speaker division of Detrola? I never saw the connection with the names until tonite, I know dim pilot bulb I am.
btw beware if you go to the Detrola site frequently googled up, it is on Tripod and has many threats to your computer. i am sure they are not intentional but Norton goes wild when I hit that site.
Here is the lookalike..i have seen a Philco styled like this, I thinks.
http://www.radioatticarchives.com/radio.htm?radio=5420
Threads: 566
Yep looks like one of the 66-s.
Threads: 54
Rola was just a speaker manufacturer as far as I know, much like Utah or Quam Nickels, I've seen their speakers used in a bunch of different makes and models not just Detrola. Besides that Detrola was really not a large enough manufacturer to have bought out a speaker manufacturer, or made their own. Or were you thinking that the 'rola portion of Det-rola had something to do with the speaker company? I think that ending a radio or phonograph manufacturer's name in 'olla was just something that began in the early days of gramophones and carried on longer then it needed to, like Victrola, Graphonola, Phonola, Radiola, Audiola, since Detrola sets were made in Detroit they just dropped the "it" and added "la".
Yes the styling of that set is very similar to that of a Philco 60MB or 66MB, but was likely inspired by the Philco models rather then the other way around. Philco used their own stylists that they had in house but also hired outside stylists like Norman Bel Geddes to design cabinets, Detrola may have done the latter but more then likely they just hired an outside cabinet/furniture company to design and produce the cabinets for them.
Dennis Smith (Mr Detrola) may know for sure what they did over at Detrola, he apparently had an Aunt that worked for the company hence his person interest in the history and products of the firm, but most of the small and mid sized radio manufacturers did not have their own cabinet shops and contracted out. They would go to a cabinet company and if they did not have something that was already available off the shelf the cabinet company would submit a few designs for the radio manufacturer's approval, which they would then build.
(This post was last modified: 03-22-2015, 04:50 AM by Arran.)
Threads: 416
City: Boston
Thanks for the perspecitive and info.
Threads: 566
Also Motorola.
Threads: 54
(03-22-2015, 05:01 PM)morzh Wrote: Also Motorola.
Can't forget Motorola, who's original company name was Galvin Manufacturing Company, their original line of business was to manufacture radios for cars, hence the name "Motor-ola". Then they got into portable radio equipment like for taxi cabs, and cop cars, then they developed the Handi Talky during the war. Unfortunately they were bought by Poohgle, who really knew nothing about manufacturing hardware, so they broke it up and sold off parts of Motorola to some Korean and Chinese purveyors of junk electronics, except for those parts the U.S government forbade them to sell for security reasons.
Threads: 2
City: Southport NC
Threads: 416
City: Boston
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
