Philco 18 code 121 RF coil rewind
I am new to the phorum and am in the process of restoring a Philco Model 18 Code 121.  I already knew that some of the rf coils would have open primaries, and on this model it is the detector transformer #10 which is supposed to measure 3.7 ohms and the oscillator transformer #16 which is supposed to measure 3.4 ohms.
On the repair bench website I have read the service hints article on the rewinding of these coils. The only models listed are the 20, 70, using 32 gauge and the 90 using 34 gauge.  It is hard to determine from the original windings as they are really rough.
I would like to know if anyone has rewound the coils on a model 18 and what gauge enamel wire did you use and turns involved?
Any and all help is very much appreciated!
Welcome to the Phorum!! Have not rewound an 18 but someone will chime in here I'm sure. One caution often repeated here....make note of the direction of the winding!
Jason
Today wire of the same gauge might be a bit thicker due to thicker warnish coating.
Still you could simply use calipers and the gauge table to see what it was.
I think I used gauge 32 on most of my Philco (and others) RF coils.
Simply count turns and note winding direction. Make sketches, always helpful and is something to fall back on when you forget how it was before.
Those are simple 1-layer coils, no magic to it.
Ask if you need to bake the bobbins in this particilar case before you wind.
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
Model 27-84 BUZZ?Humm?
There are currently 1395 online users. [Complete List]
» 1 Member(s) | 1394 Guest(s)
