Electrolytic capacitor polarity - 16X code 126
Hello, all:
I'm working on a Philco 16X, chassis code 126, and have a question about the polarity of the electrolytic capacitors C98 ( 8uf) and C91, a dual can containing both a 10uf and 8uf cap.
This power supply section looks very much like the 14B I recently worked on and, in that scenario proves to be a parallel, then the 10uf section of C91 should see its positive lead going to ground.  If I'm right so far, would the negative leads of the two 8uf caps go to the negative lead of the 10uf cap?
The schematic is here:  http://www.nostalgiaair.org/PagesByModel...013141.pdf
Wonder why Philco didn't make this clear on their schematics?  Maybe they feared that some unenlightened hobbyist would. try to decipher their intent 80 years into the future?
Thank you, in advance, for replies.
Mike, K9UW
Amherst, WI
Yes that is correct.
All three negative leads connect together and go to the center tap of the power transformer, the most negative point in the power supply.
Thanks, Mondial!
I'll solder with confidence in the morning.
Mike, K9UW
Amherst, WI
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
There are currently 1475 online users. [Complete List]
» 2 Member(s) | 1473 Guest(s)
