Philco 42-1012 Antenna ??
ALL, Looking at the schematic part 1A is where the FM antenna is hooked to on Pins 1 & 2. Lookls like pins 3 and 4 are not hooked to anything.. Should they be? or maybe shorted? Why would there be wires to the part if they weren't to be used? Please see schematic.. Part 5 is the Brdcat Aerial Transformer
[Image: http://i292.photobucket.com/albums/mm38/...uqfz7x.jpg]
Thanks
Skip...
Schematic and notes here!
http://www.nostalgiaair.org/PagesByModel...013494.pdf
Seems like the built in dipole for FM is ion 1 and 2. For external dipole connect to these pins. Pins 3 and 4 are for external AM/SW long wire (3) and ground (4). At least that what the notes say.
Thanks, I should of read the manual more carefully. That answers my question.. Thanks again
You may close this
SKip...
Philco 630csx power cord
New member
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
There are currently 1424 online users. [Complete List]
» 2 Member(s) | 1422 Guest(s)
