Prepackaged Capacitor Pack for 38-116?
Hello all, I posted here a couple of years back about restoring a 38-116 Code 125 http://www.philcoradio.com/phorum/showth...hp?tid=768 . I STILL haven't gotten around to it but might start this winter. Do any of you know if a retailer sells a prepackaged capacitor pack for this radio for all the caps it uses? Seems easier to have everything at once before I begin than to have to place multiple orders as I find what I need. Thanks,
Ed
Ed,
I believe that Dave at Justradios will put together a capacitor kit for your radio if you request it:
http://www.justradios.com/
Carl
Northern Panhandle, WV
Thanks, I'll do that!
There are currently 9891 online users. [Complete List]
» 1 Member(s) | 9890 Guest(s)
