Kennedy XV (1924)
Does anyone out there have a Kennedy XV (Model 15)? This is the sloping front panel model with 5 tubes stuck in into it.
The schematic is a nightmare beyond belief. How does B+ ever get to the middle tube (1st audio) without a transformer? Tonight I will try putting a few hundred ohms across the "Stage 1" jack and hope for RC coupling from the first audio to the second audio stage.
Pete AI2V
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 7731 online users. [Complete List]
» 2 Member(s) | 7729 Guest(s)
