Philco 46-1226 code 125---7AF7 schematic
             Icon_cry Icon_cry  Where can "we " get a schematic with the right paper work from???? I order 46-1226 code 125 schematic(which is suppose to have 7AF7 tube),,,and get 46-1226 schematic ,,,with the add-on changes,121,,,122,,,125 ,,,LIKE the ones Ron has put up on the site,,,,,schematic DOESN'T have the 7AF7 tube on there,,,soo,,I though I could figure out the pins,,,which I did,,,But,,there are resistors on that tube that don't Jive with the 46-1226 schematic,,,does the 46-1226 code 122 be the same as the 46-1226 code 125,, Icon_crazy Icon_crazy Icon_crazy ,,thank you for all help,,Ken
There are currently 5924 online users. [Complete List]
» 2 Member(s) | 5922 Guest(s)
