Alignment Tool
Does anyone know where I can find an insulated alignment tool with a 1/4" hex socket for adjusting tuning capacitors and IF adjustments.  I had one years ago but can not find one today.  The kits that the on-line Electronic stores sell do not have the hex socket in them  I have restored 2 Philco radios, Models 80 & 81.  You can not use a metallic tool for adjustments on these radios.
Thanks very much to anyone who can help.
See this post for some options http://philcoradio.com/phorum/showthread...4#pid97344
(09-29-2015, 09:36 PM)klondike98 Wrote:  See this post for some options http://philcoradio.com/phorum/showthread...4#pid97344
Thanks!   I think I can make one.  Icon_lol
Amazing things can be crafted from chopsticks rejected from the kitchen by my better half, so long as they are dried off.
As recall those Philco hex adjustments are at ground potential so you can use pretty much any metallic tool for tuning.
Pete AI2V
Quote:As recall those Philco hex adjustments are at ground potential
That is true for the 80 and 81 but, don't assume this is so for all Philcos. Some Philco models have trimmers on the primary of the IFs, those will have B+ on them.
M R Radios   C M Tubes
OUCH!!!! Spark Spark!!!!!!!
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 1129 online users. [Complete List]
» 1 Member(s) | 1128 Guest(s)
