Need picture of the back of a Philco 38-60B
My first post and of course I want something. I have a 38-60 tombstone that I now have working fine and am now ready to start on the cabinet. My first problem is that the radio does not have a back on it thus I need a picture of the back of one so I can make a back for it. Also, what material do most of you normally use for a back?
Don
Welcome to the Phorum!
Icon_wave
I do not believe Philco had backs on those.
Update..a quick search of the Phorum and I found Ron saying no US made cathedral or tombstone made before1939 had a back.  See
http://philcoradio.com/phorum/showthread...5#pid11805
(11-24-2015, 12:29 AM)klondike98 Wrote:  Welcome to the Phorum!
Icon_wave
Thanks for the prompt response, it was appreciated and I believe correct as all of the images I can find do not have a back on them. My only hint that there might have been a back at one time was the fact that with a great imagination I thought it looked like there was some tiny nail holes in the back on the cabinet.
Have a great Thanksgiving,
Don
There are currently 8834 online users. [Complete List]
» 2 Member(s) | 8832 Guest(s)
