1941-42 Philco Radio Model #50-T
I have just installed a nice 1941-42 Philco Products Ltd, Toronto, Canada table model #50-T radio in my kitchen.
It sounds pretty good but I'm wondering how do you set the five station push buttons. One button if for off/on and the other five are not doing anything right know. I can tune stations manually but not with the buttons.
Any suggestions of what to do or where to get a users manual. Hope somebody can lend a hand. Warm regards
Gord Morrison up in Canada.
 Hi Gordon, I tried to find info you need but couldn't. You might try
 Just Radios
they sell schematics and are in Canada. I think a lot of the push button adjustments are fairly simular, you migt try searching for the 1940/41 USA. made philcos with push button tunning and read how to adjust.
        Good luck.
Hi Gord Welcome to the Phorum!
Try looking here for one that looks like it:
http://philcoradio.com/gallery/1940b.htm
or
http://philcoradio.com/gallery/1941a.htm
Then look up the US model # here:
http://www.nostalgiaair.org/Resources/303/T0000303.htm
As Mike said most are pretty generic.
Unfortunately, the Philco (Canada) 50 does not have a USA equivalent.
It is very similar to the Canadian 51A, but with a single ended output instead of the push-pull output in the 51A.
I own a 51AT and I wrote about its restoration here just over a year ago:
http://philcoradio.com/phorum/showthread.php?tid=11039
As Mike mentioned, try Just Radios for the schematic.
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
Model 27-84 BUZZ?Humm?
