41-245 dial string diagram
I have the 1941 Philco Yearbook of all of the schematics for the year, but it doesn't contain the dial string diagram. The string is missing for the band switch indicator light (along with the shroud that went around the bulb socket to deflect the light to the proper indicator light on the dial panel). Does anyone have a copy of this diagram they could scan and post here or e-mail to me? I'd be most grateful. It doesn't look too complicated, but I am missing a few parts (probably a spring and a hook) that I'll need to fabricate to make it work again. Thanks!
