Philco station letters?
Will the call letters for a 42-380 fit a 40-180? Where the all the same?
They should fit quite well. Copies of the sheets of station call letters are on this phorum in the helpful downloadable files. It is actually the first post on the new forum.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7091 online users. [Complete List]
» 1 Member(s) | 7090 Guest(s)
