Philco Model 89 ( Code 123 )
I am working on a Philco Model 89 (Code 123 ). I need to find out where to go to look for the information on the six bakelite capacitor modules. Can anyone suggest some help to me?
nv3g
Chuck Schwark's Philco repair bench has some info on them.
http://www.philcorepairbench.com/bblokcap.htm
Some more info right here:
http://philcoradio.com/tech/blocks.htm
