Philco 650px phono
Does this look like the original set up, the tone arm I know isn't right and I think I have one in storage that will work, its one of those RCA tone arms with manganic pickup like the one shown from my Philco 23x (RIGHT?) Icon_think  I will have to plug the hole with something that they put in the board where the tone arm is now. Singer is the maker of motor assembly, it that what philco used for this 650px. It looks factory to me except for someone modified with deferent tone arm
I found a correct tone arm for this phono, this set up is original for the Philco 650px. Thanks for all the response on this thread
 I can't speak to the originality know nothing about phonos, but it sure looks good.
There are currently 5557 online users. [Complete List]
» 1 Member(s) | 5556 Guest(s)
