Philco Console 37-61
Philco Console 37-61...Would a regular (todays) speaker work on this or does it have to be a tube amp speaker...
the original has 3 wires wound together---what would happen if a regular speaker was connected to the old wiring..I was told a regular speaker would make a loud humming noise..
Hi
The original speaker used in your Philco was an electrodynamic type, which used a field coil (electromagnet) instead of a permanent magnet, to produce a magnetic field which makes the speaker work. Of course, permanent magnets now perform that job which do not require electrical energy to produce the magnetic field.
This field coil is, often, part of the radio's power supply; specifically, it is used as a filter choke in many applications. This is the case with your 37-61.
Yes, it can be replaced with a permanent magnet speaker...but then, you also need an audio output transformer to match the audio output of the receiver to the voice coil of your replacement speaker...which will be a different value than original. In addition, you have to replace the resistance of that original field coil with something. A power resistor, 1000 ohms @ 25 watts will work as a substitute for the field coil, but you may have to increase the value of the set's electrolytic (filter) capacitors to make up for the increased hum due to the loss of the field coil.
Gloritone 27 Radio
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Restoring Philco 96
Nice find! I hope it completes your console.jrblasde — 08:45 AM
Gloritone 27 Radio
Hello john, That, is the first time I have have seen or heard of that brand and model. Welcome to the party !! Sincer...radiorich — 08:08 AM
Thank you! I’ll probably use the half-round molding and tone it to match the original. Thanks for the replies!Max T — 06:34 AM
Gloritone 27 Radio
I'm kind of late to this thread, but Buzz1151 has a 3 part restore series on the model 27: A little bit of extra t...Eliot Ness — 05:48 AM
You can get half-round moulding in various diameters at any home improvement store. That way the flat edge is uniform. ...GarySP — 12:03 AM
42-345 Resistors
Great comments. I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb ...proftrussell — 11:12 PM
