Philco 112X help
I have a Philco 112X. There is a filter condenser block with 6 condensers inside. They're all shown on the schematic, but with no values. Any idea how to obtain the values of the condensers?
See if this is the same schematic:
http://www.philcoradio.com/tech/images/112b.jpg
Yes it is. And it has the values listed! I appreciate it, thanks.
There are currently 6714 online users. [Complete List]
» 2 Member(s) | 6712 Guest(s)
