philco speaker cloth
hello I am looking for some speaker cloth and frame fro a philco 90 seams to be many patterns out there dose any one know what would be the right one for this
benny
(04-03-2016, 04:07 PM)mg34.42 Wrote:  hello I am looking for some speaker cloth and frame fro a philco 90 seams to be many patterns out there dose any one know what would be the right one for this
benny
You can get a reproduction frame on ebay and the reproduction cloth is availably at Radio Daze. Look for this pattern , the 90 is the same as the philco 70.
