Photo finish stripping
I have a Zenith 6S-229 with the burled photo finish. The clear coat/laquer finish has many very fine "cracks" in it. I assume due to the many years of sunlight. I want to strip/remove the clear coat without damaging the photo finish/color. Any suggestions? Thanks
Hi
I am not aware of any stripper/remover that will not remove the photofinish along with the clear lacquer finish coat.
Eico 232 VTVM Schematic
There are currently 6691 online users. [Complete List]
» 3 Member(s) | 6688 Guest(s)
