Bathtub Cap 7653 C ???? ID
Not able to locate any in the listing of bathtub Caps.
Looks like it is an update to the early 16 chassis.
Contains 2 Caps Value ????
Bob T
.025 x 2
Tim
Thank You
I just found it on a update sheet by Philco .025 it is
Bob T
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4801 online users. [Complete List]
» 1 Member(s) | 4800 Guest(s)
